{"product_id":"einhell-tp-ro-18-set-li-bl-router-kit-18v-body-only","title":"Einhell TP-RO 18 Set Li BL Router Kit 18V (Body Only)","description":"\u003cp\u003eThe Einhell TP-RO 18 Set Li BL-Solo Power X-Change Router\/Palm Router is powered by the Einhell PurePOWER brushless motor. This brushless motor offers more power and a longer running time than conventional carbon brush motors. After registering online, the brushless motor comes with a 10-year warranty. Together with a powerful motor, the variable speed control electronics can be perfectly adapted to any task in soft or hard wood.\u003c\/p\u003e\u003cp\u003eThe cutting depth can be infinitely adjusted and features an additional fine adjustment. Depth adjustment is performed with a multi-setting turret stop. The router is equipped with a precise twin-tube guide, a clamp (6mm and 8mm), and a spindle lock for easy tool changes. The LED light ensures the working area is perfectly illuminated. A plastic insert protects the surface of the workpiece.\u003c\/p\u003e\u003cp\u003eThe soft grip handle makes for ergonomic and safe working, while the chip shield protects the user against wood chips in the field of vision, and the two-handed attachment helps to keep the unit under precise control during use. The edge trimmer base also allows edges to be beveled.\u003c\/p\u003e\u003cp\u003eSupplied with 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e collet sleeve, 6mm and 8mm collets, a parallel stop, compass tip, a copy sleeve and assembly tool, along with an extraction adapter for Einhell wet and dry vacuum cleaners and a handy storage bag for clean and safe transport.\u003c\/p\u003e\u003cp\u003ePart of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required\u003c\/p\u003e\u003cp\u003eSupplied as body only (no battery or charger).\u003c\/p\u003e\u003cp\u003eSpecifications:\u003c\/p\u003e\u003cp\u003eCollet Diameter: 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e, 6 \u0026amp; 8 mm.\u003c\/p\u003e\u003cp\u003eSpeed (Min.\/Max.): 10,000\/30,000\/min.\u003c\/p\u003e\u003cp\u003eLift Height Edge Router Attachment: 40mm.\u003c\/p\u003e\u003cp\u003eLift Height Router Attachment: 35mm.\u003c\/p\u003e\u003cp\u003eMax. Shape Cutter: 30mm.\u003c\/p\u003e\u003cp\u003eSuction Adaptor Diameter: 35mm.\u003c\/p\u003e\u003cp\u003eWeight: 1.34kg.\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54118774210907,"sku":"113550","price":145.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113550_xl.jpg?v=1789791197","url":"https:\/\/www.axminstertools.com\/products\/einhell-tp-ro-18-set-li-bl-router-kit-18v-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
