{"product_id":"einhell-tr-ro-1400e-router-1-4-230v","title":"Einhell TR-RO 1400E Router 1\/4\" 230V","description":"\u003cp\u003eThe Einhell TP-RO 1400 E Professional Router is a powerful and versatile solution for precise routing work in the workshop or garage. Equipped with a robust 1,400W motor, a variable no-load speed of 10,000-30,000rpm, and a generous 55mm plunge depth, it is ideal for demanding routing tasks, including work on hard materials and deep cuts.\u003c\/p\u003e\u003cp\u003eThe router features continuously adjustable electronic speed control, allowing the speed to be matched precisely to the material being worked on. Infinitely variable depth adjustment, complemented by a fine adjustment function, enables accurate and controlled plunging into the workpiece for high-precision results.\u003c\/p\u003e\u003cp\u003eA stable double-tube guide system with solid guide bars provides excellent control and dimensional accuracy, while the multi-stage turret stop ensures consistent depth settings for repeated operations. The router is supplied with 6mm and 8mm collets, making it compatible with a wide range of router bits, and the integrated spindle lock allows for quick and straightforward cutter changes.\u003c\/p\u003e\u003cp\u003eTo help protect delicate work surfaces, the base plate is fitted with a plastic insert that prevents scratches and marks. The ergonomic design includes soft-grip handles and an optimised switch position for safe and comfortable two-handed operation. An integrated LED work light illuminates the cutting area for improved visibility, while the foldable chip breaker cover offers protection from flying debris. For a cleaner working environment, the supplied extraction adaptor can be connected to a compatible extractor (adaptor size 40mm outside diameter\/35mm inside diameter).\u003c\/p\u003e\u003cp\u003eSupplied complete with three collets (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e, 6mm and 8mm), an open-ended wrench, compass tip, parallel guide, copy sleeve, extraction adaptor, and foldable chip breaker cover, the TP-RO 1400 E is ready for a wide variety of routing applications straight out of the box.\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54255612952923,"sku":"114925","price":109.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114925_xl.jpg?v=1791242018","url":"https:\/\/www.axminstertools.com\/products\/einhell-tr-ro-1400e-router-1-4-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
