{"product_id":"einhell-varrito-multi-tool-18v-body-only","title":"Einhell VARRITO Multi Tool 18V (Body Only)","description":"\u003cp\u003eThe Einhell VARRITO Cordless Power X-Change Multi-Tool is a flexible, high-quality helper for extension and renovation jobs. Speed electronics enables the tool to be adjusted to the particular material and application. Designed for safe, ergonomic operation, fitted with a soft grip and an oscillation decoupled battery uptake for reduction of vibration.\u003c\/p\u003e\u003cp\u003eThe quick-release helps you to change accessories without additional tools. With magnetic tool fixation for getting the tool ready quickly. The 12-pin tool fixation enables flexible positioning of equipment.\u003c\/p\u003e\u003cp\u003ePart of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.\u003c\/p\u003e\u003cp\u003eSupplied with:\u003c\/p\u003e\u003cp\u003e1 x Triangular Grinding\/Sanding Plate.\u003c\/p\u003e\u003cp\u003e9 x Grinding\/Sanding Paper (3 x P60, 3 x P80, 3 x P120).\u003c\/p\u003e\u003cp\u003e1 x Scraper.\u003c\/p\u003e\u003cp\u003e1 x HCS Plunge-Cut Saw Blade for Wood and Plastic.\u003c\/p\u003e\u003cp\u003e1 x BIM Plunge-Cut Saw Blade for Metal.\u003c\/p\u003e\u003cp\u003e1 x HSS Segment Saw Blade for Wood, Plastic and Soft Metal.\u003c\/p\u003e\u003cp\u003e1 x Diamond Segment Saw Blade for Tile Joints.\u003c\/p\u003e\u003cp\u003eSupplied as body only (no battery or charger).\u003c\/p\u003e\u003cp\u003eSpecifications:\u003c\/p\u003e\u003cp\u003eNo Load Speed: 22,000 - 40,000\/min.\u003c\/p\u003e\u003cp\u003eOscillation Angle: 3.2°.\u003c\/p\u003e\u003cp\u003eSandpaper Size: 90 x 90 x 90mm.\u003c\/p\u003e\u003cp\u003eWeight: 1.02kg.\u003c\/p\u003e","brand":"Einhell","offers":[{"title":"Default Title","offer_id":54118756974939,"sku":"113541","price":68.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113541_xl.jpg?v=1789791154","url":"https:\/\/www.axminstertools.com\/products\/einhell-varrito-multi-tool-18v-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
