A fine classic design of pen available either as a fountain pen or rollerball. The Executive would make a great gift either individually or as a pair. With a gold finish and a raised silver ring around the centre band, the simple uncluttered lines of this pen will make a classy gift. Use timber or acrylic to produce your own unique designs.
A blank of at least 22mm square will be required to make these pens. 37/64 and 15/32" drill bits required. When using a mandrel to make these pens, bushing set 502691 will be required.
Pen Kit Classification Master
Difficulty Beginner
Drill Bit Required 15/32 37/64
Bushing Set Order No. 502691
Minimum Blank Size 22 mm x 22 mm x 140 mm
Pen Type Rollerball Pen
Refill Order Number 340240
Colour Gold Web Attribute Set: Project Kits
EAN Barcode 5052511055319
