The Faithfull Carpenter's Tool Kit comprises of five essential tools for anyone working with wood. Contained in a wooden presentation box, which is a great way to store the tools are three vital marking tools plus two of the most used planes.
The set includes:
230mm Try Square, has a hardwood stock with twin brass faces and black spring steel blade. Three-brass rivet fixings ensure lasting 90
230mm Sliding Bevel, for anything other than 90
Mortice and Marking Gauge, another vital piece of equipment for marking parallel lines. It is made with a knurled brass thumb screw and thumb slide adjustment, the stock is hardwood with brass wear plates.
No .4 Smoothing Plane; by far the most widely used bench plane. Suitable for sizing and smoothing both hard and soft woods. The No. 4 features depth and lateral blade adjustment. It has a hardwood handle and knob for added comfort. 50mm wide blade, overall Length: 254mm.
No. 60.1/2 Block Plane; a highly useful, low angle block plane. Whether it’s a quick chamfer, cleaning end grain or trimming laminates. The 60./12 features a fully adjustable mouth for coarse or fine work, and depth and lateral adjustment. 35mm wide blade set at the low angle of 13.5
Note: Faithfull planes represent excellent value for money. As such they may not be quite as refined as more expensive examples. A little work sharpening the blade and maybe some minor fettling will be most rewarding.
