{"product_id":"faithfull-5-piece-carpenters-tool-kit","title":"Faithfull 5 Piece Carpenter's Tool Kit","description":"\u003cp\u003eThe Faithfull Carpenter's Tool Kit comprises of five essential tools for anyone working with wood. Contained in a wooden presentation box, which is a great way to store the tools are three vital marking tools plus two of the most used planes.\u003c\/p\u003e\u003cp\u003eThe set includes:\u003c\/p\u003e\u003cp\u003e230mm Try Square, has a hardwood stock with twin brass faces and black spring steel blade. Three-brass rivet fixings ensure lasting 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e accuracy.\u003c\/p\u003e\u003cp\u003e230mm Sliding Bevel, for anything other than 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e this quality sliding bevel has a hardwood stock, spring steel blade with brass end caps and a wing nut. The blade locks in position by means of a brass wing nut to set and transfer angles.\u003c\/p\u003e\u003cp\u003eMortice and Marking Gauge, another vital piece of equipment for marking parallel lines. It is made with a knurled brass thumb screw and thumb slide adjustment, the stock is hardwood with brass wear plates.\u003c\/p\u003e\u003cp\u003eNo .4 Smoothing Plane; by far the most widely used bench plane. Suitable for sizing and smoothing both hard and soft woods. The No. 4 features depth and lateral blade adjustment. It has a hardwood handle and knob for added comfort. 50mm wide blade, overall Length: 254mm.\u003c\/p\u003e\u003cp\u003eNo. 60.1\/2 Block Plane; a highly useful, low angle block plane. Whether it’s a quick chamfer, cleaning end grain or trimming laminates. The 60.\/12 features a fully adjustable mouth for coarse or fine work, and depth and lateral adjustment. 35mm wide blade set at the low angle of 13.5\u003cspecial id=\"8\"\u003e\u003c\/special\u003e.\u003c\/p\u003e\u003cp\u003eNote: Faithfull planes represent excellent value for money. As such they may not be quite as refined as more expensive examples. A little work sharpening the blade and maybe some minor fettling will be most rewarding.\u003c\/p\u003e","brand":"Faithfull","offers":[{"title":"Default Title","offer_id":54118489293147,"sku":"109660","price":108.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109660_xl.jpg?v=1789782286","url":"https:\/\/www.axminstertools.com\/products\/faithfull-5-piece-carpenters-tool-kit","provider":"Axminster Tools","version":"1.0","type":"link"}
