The Faithfull Security Screwdriver Bit Set provides a comprehensive selection of bits for driving and removing both standard and tamper-resistant fasteners. With 60 Chrome Vanadium steel bits covering the most commonly used drive types, it is an ideal choice for tradespeople, maintenance tasks and general workshop use.
Covering Phillips, Pozidriv, Slotted, Hex, Torx, Tamperproof Torx, Hex Security and Spanner drives, the set offers excellent versatility across a wide range of applications. The bits are neatly organised in a durable plastic case and supplied with a magnetic bit holder for secure bit retention.
Faithfull is renowned for producing reliable, hardworking tools and accessories that deliver dependable performance and excellent value for professional and DIY users alike.
Supplied With
6 x Phillips bits: PH0, PH1, PH2 (x3), PH3
6 x Pozidriv bits: PZ0, PZ1, PZ2 (x3), PZ3
5 x Slotted bits: 3, 4, 5, 6 & 7mm
12 x Hex bits: 1.5, 2, 2.5, 3, 3.5, 4, 4.5, 5, 5.5, 6, 7 & 8mm
13 x Torx bits: T5, T6, T7, T8, T9, T10, T15, T20, T25, T27, T30, T35 & T40
7 x Tamperproof Torx bits: TT10, TT15, TT20, TT25, TT27, TT30 & TT35
6 x Hex Security bits: 2, 2.5, 3, 4, 5 & 6mm
5 x Spanner bits: 4mm (x2), 6mm, 8mm & 10mm
1 x 60mm magnetic bit holder
Plastic storage case
Web Attribute Set Screwdriver Bits
EAN Barcode 5023969250090
