{"product_id":"faithfull-depressed-centre-metal-cutting-disc-115mm","title":"Faithfull Depressed Centre Metal Cutting Disc 115mm","description":"\u003cp\u003eDepressed Centre Metal Cutting Discs are made with aluminium oxide abrasive grit, reinforced with fibreglass, and resin‑bonded for safety and reliable cutting performance. The 1.8mm discs allow precise, fine cutting on stainless steel and high‑grade metals, while the depressed centre design improves grinder versatility by providing better access in tight or angled applications.\u003c\/p\u003e\u003cp\u003eFor best performance, metal cutting discs should always be used at a 90º angle to the workpiece. They are suitable for a wide range of machines—from mini‑grinders to stationary cut‑off saws. Always select the correct disc type (metal or stone) for the material and ensure it is mounted correctly.\u003c\/p\u003e\u003cp\u003eManufactured to EN 12413 standards.\u003c\/p\u003e\u003cp\u003eSuitable for 115mm and 125mm grinders with 22.23mm bore.\u003c\/p\u003e\u003cp\u003eSafety Tips\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Read and follow the manufacturer’s instructions\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Wear goggles to protect against chips and dust\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Check the disc condition regularly\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Adjust the guard to deflect sparks and debris\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Maintain consistent speed—let the disc do the cutting\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Do not use Depressed Centre cutting discs for grinding\u003c\/p\u003e","brand":"Faithfull","offers":[{"title":"Default Title","offer_id":54118843056475,"sku":"114214","price":0.96,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114214_xl.jpg?v=1789793256","url":"https:\/\/www.axminstertools.com\/products\/faithfull-depressed-centre-metal-cutting-disc-115mm","provider":"Axminster Tools","version":"1.0","type":"link"}
