Depressed Centre Metal Cutting Discs are made with aluminium oxide abrasive grit, reinforced with fibreglass, and resin‑bonded for safety and reliable cutting performance. The 1.8mm discs allow precise, fine cutting on stainless steel and high‑grade metals, while the depressed centre design improves grinder versatility by providing better access in tight or angled applications.
For best performance, metal cutting discs should always be used at a 90º angle to the workpiece. They are suitable for a wide range of machines—from mini‑grinders to stationary cut‑off saws. Always select the correct disc type (metal or stone) for the material and ensure it is mounted correctly.
Manufactured to EN 12413 standards.
Suitable for 115mm and 125mm grinders with 22.23mm bore.
Safety Tips
