Depressed Centre Metal Grinding Discs are made with aluminium oxide abrasive grit, reinforced with fibreglass and resin‑bonded for strength, safety and effective cutting performance. They are designed for stock removal on both ferrous and non‑ferrous metals. For best efficiency, use the disc at a 45° angle. Suitable for a wide range of equipment, from mini‑grinders to stationary cut‑off machines.
Manufactured to EN 12413 standards.
Choosing the correct disc for the material is essential, and all wheels must be properly mounted before use.
Suitable for 115mm and 125mm grinders with 22.23mm bore.
Safety Tips:
Follow the manufacturer’s instructions
Wear eye protection
Inspect the disc regularly
Adjust the guard to deflect sparks
Maintain steady speed and let the disc work
Web Attribute Set Angle Grinder Discs
EAN Barcode 5023969205083
