Depressed Centre Stone Cutting Discs are manufactured using silicone carbide abrasive grit, reinforced with fibreglass and resin‑bonded to deliver safe, reliable cutting performance. The depressed centre design increases versatility by providing better access in restricted or angled applications when used with an angle grinder.
Stone cutting discs must always be used at a 90º angle to the workpiece and must never be used for grinding. Suitable for a range of machines, from mini‑grinders to stationary cut‑off saws.
Manufactured to EN 12413 standards.
Safety Tips
Read the manufacturer’s instructions carefully
Wear goggles to protect against chips and dust
Inspect the disc regularly for damage or wear
Adjust the guard to deflect sparks and debris
Maintain consistent speed—let the disc do the cutting
Web Attribute Set Angle Grinder Discs
EAN Barcode 5023969204949
