Depressed Centre Stone Grinding Discs are made from silicone carbide abrasive grit, reinforced with fibreglass and resin‑bonded for strength, safety and reliable cutting performance. They are designed for efficient stock removal on stone and concrete. For best results, present the disc to the workpiece at a 45° angle. Suitable for a wide range of machines, from mini‑grinders to stationary cut‑off tools.
Manufactured to EN 12413 standards.
Safety Tips:
Always read the manufacturer’s instructions
Wear goggles to protect against flying debris
Check the disc’s condition regularly
Position the guard to deflect sparks and dust
Maintain consistent speed and let the disc do the work
Web Attribute Set Angle Grinder Discs
EAN Barcode 5023969205076
