{"product_id":"faithfull-inox-cutting-disc-1-2mm-x-125mm","title":"Faithfull Inox Cutting Disc 1.2mm x 125mm","description":"\u003cp\u003eThe Faithfull Inox Cutting Disc delivers fast, exceptionally clean cuts with minimal effort. Designed for precise, low‑vibration metal cutting, it is made from aluminium oxide abrasive grit and reinforced with fibreglass, then resin‑bonded for strength and consistent performance. This construction ensures high cutting speeds, low material loss and reduced noise.\u003c\/p\u003e\u003cp\u003eSuitable for applications such as car body repairs, tank construction, steel cable cutting, and working with thin‑walled profiles and pipes made from stainless steel, non‑ferrous metals and composite materials.\u003c\/p\u003e\u003cp\u003eManufactured to EN 12413 standards.\u003c\/p\u003e\u003cp\u003eSafety Tips:\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Always read the manufacturer’s instructions\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Wear protective goggles\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Inspect the wheel regularly\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Adjust the guard to deflect sparks and dust\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"14\"\u003e\u003c\/special\u003e Maintain steady speed and let the disc work\u003c\/p\u003e\u003cp\u003eSpecification:\u003c\/p\u003e\u003cp\u003eDiameter: 125mm\u003c\/p\u003e\u003cp\u003eThickness: 1.2mm\u003c\/p\u003e\u003cp\u003eBore: 22.23mm\u003c\/p\u003e\u003cp\u003eMax. RPM: 12,250\u003c\/p\u003e","brand":"Faithfull","offers":[{"title":"Default Title","offer_id":54118843154779,"sku":"114216","price":0.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114216_xl.jpg?v=1789793271","url":"https:\/\/www.axminstertools.com\/products\/faithfull-inox-cutting-disc-1-2mm-x-125mm","provider":"Axminster Tools","version":"1.0","type":"link"}
