The Faithfull Inox Cutting Disc delivers fast, exceptionally clean cuts with minimal effort. Designed for precise, low‑vibration metal cutting, it is made from aluminium oxide abrasive grit and reinforced with fibreglass, then resin‑bonded for strength and consistent performance. This construction ensures high cutting speeds, low material loss and reduced noise.
Suitable for applications such as car body repairs, tank construction, steel cable cutting, and working with thin‑walled profiles and pipes made from stainless steel, non‑ferrous metals and composite materials.
Manufactured to EN 12413 standards.
Safety Tips:
Always read the manufacturer’s instructions
Wear protective goggles
Inspect the wheel regularly
Adjust the guard to deflect sparks and dust
Maintain steady speed and let the disc work
Specification:
Diameter: 125mm
Thickness: 1.2mm
Bore: 22.23mm
Max. RPM: 12,250
Web Attribute Set Angle Grinder Discs
EAN Barcode 5023969000077
