Faithfull Multi-Cut Cutting Discs are designed to handle a broad range of materials commonly found in construction and fabrication. With a slim 1mm profile, they deliver fast, efficient cutting with reduced waste and minimal dust. Perfect for tackling mixed-material tasks, these discs excel when working with modern composite materials used across various industries.
Engineered for versatility, they cut effortlessly through sheet metal, stainless steel (inox), pipes, profiles, brick, stone, ceramic tiles, plastics, PVC, and other typical building materials.
Available in the two sizes, each pack includes ten discs supplied in a durable metal storage tin—ideal for protection, organisation, and long-term safekeeping.
Disc Diameter 115 mm
Web Attribute Set Angle Grinder Discs
EAN Barcode 5023969287683
