The Faithfull Copper Chopper is the perfect tool for making clean burr-free cuts in 22mm copper pipes. It is ideal for use in confined or awkward places and it can be operated using only one hand. Simply clip the tool onto the pipe and rotate the cutter in the direction of the arrow shown on the cutter body until the pipe is cut clean through. The Copper chopper is designed to cut 22mm copper pipe only, and not for use when cutting pipes manufactured from other materials such as stainless steel or plastic, replacement cutting wheels are available.
Web Attribute Set Plumbing Tools
EAN Barcode 5023969264974
