{"product_id":"faithfull-universal-drain-rod-set","title":"Faithfull Universal Drain Rod Set","description":"\u003cp\u003eFor blocked drains, these Faithfull Universal Drain Rods will remove or clear whatever is causing the obstruction. The set comprises ten polypropylene drain rods plus a 100mm rubber plunger, and a 50mm double worm screw. Each rod is 920mm long giving you a potential reach of up to 9 metres. Each 920mm polypropylene drain rod has crimped and pinned rust-proof, heavy-duty screw connector. With the rods screwed together be careful to only turn the rods clockwise.\u003c\/p\u003e\u003cp\u003eThese rods are good quality and strong and can be relied upon to get the job done quickly when needed.\u003c\/p\u003e\u003cp\u003eN.B ALWAYS ROTATE DRAIN RODS IN A CLOCKWISE DIRECTION.\u003c\/p\u003e","brand":"Faithfull","offers":[{"title":"Default Title","offer_id":54118491750747,"sku":"109724","price":37.72,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109724_xl.jpg?v=1789782465","url":"https:\/\/www.axminstertools.com\/products\/faithfull-universal-drain-rod-set","provider":"Axminster Tools","version":"1.0","type":"link"}
