For blocked drains, these Faithfull Universal Drain Rods will remove or clear whatever is causing the obstruction. The set comprises ten polypropylene drain rods plus a 100mm rubber plunger, and a 50mm double worm screw. Each rod is 920mm long giving you a potential reach of up to 9 metres. Each 920mm polypropylene drain rod has crimped and pinned rust-proof, heavy-duty screw connector. With the rods screwed together be careful to only turn the rods clockwise.
These rods are good quality and strong and can be relied upon to get the job done quickly when needed.
N.B ALWAYS ROTATE DRAIN RODS IN A CLOCKWISE DIRECTION.
