The Faithfull Zirconia Abrasive Jumbo Flap Discs are designed for use with angle grinders and offer up to 40% more abrasive material than standard flap discs. Made from long‑lasting Zirconia Alumina and resin‑bonded for added strength, they provide reliable performance on wood, metal, plastic and stainless steel. Their slightly conical profile makes them ideal for grinding at 15–25° angles on contoured surfaces.
Suitable for 115mm and 125mm grinders with 22.23mm bore.
This pack of three includes:
1 x 115 x 22mm, 40 Grit – for rough grinding
1 x 115 x 22mm, 80 Grit – for final grinding
1 x 115 x 22mm, 120 Grit – for smooth grinding
