The Faithfull Zirconia Abrasive Jumbo Flap Discs are engineered for use with angle grinders and contain up to 40% more abrasive material than standard flap discs. Made from durable Zirconia Alumina and resin‑bonded for added strength, they deliver long‑lasting performance on wood, metal, plastic and stainless steel. Their slightly conical shape makes them ideal for smooth grinding at 15–25° angles, especially on contoured surfaces.
This disc is designed for use with a 115mm angle grinder.
Maximum Speed: 80 m/s (13,300 RPM)
Abrasive Grit 120
Web Attribute Set Angle Grinder Discs
EAN Barcode 5023969006789
