{"product_id":"festool-104-piece-centrotec-assembly-kit-in-t-loc-case","title":"Festool 104 Piece CENTROTEC Assembly Kit in T-Loc Case","description":"\u003cp\u003eBe prepared, when it comes to putting things together, there’s bound to be an answer in this 104 piece assembly kit. Whatever the job throws at you help lies within this Systainer organiser. This kit is the ideal companion to any of the Festool cordless tools with the FastFix feature.\u003c\/p\u003e\u003cp\u003eContents comprise:\u003c\/p\u003e\u003cp\u003e5 of each 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e hex, 25mm screwdriver bits;  PZ3, PZ2, PZ1, PH1, PH2, PH3, TX15, TX20, TX25, TX30,  5.5 slotted \u0026amp;, 6.5 slotted\u003c\/p\u003e\u003cp\u003e1 each 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e hex CENTROTEC, 100mm screwdriver bits: PZ1, PZ2, PZ3, PH1, PH2, PH3, TX15, TX20, TX25, TX30, 5.5mm \u0026amp; 6.5mm slotted.\u003c\/p\u003e\u003cp\u003e1 each 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e hex CENTROTEC wood drill bits with centre point for quick, clean holes: 4mm, 5mm, 6mm, 8mm \u0026amp; 10mm.\u003c\/p\u003e\u003cp\u003e1 each 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e hex CENTROTEC deburring countersinks 2-8mm,\u0026amp; 5-15mm\u003c\/p\u003e\u003cp\u003e1 x 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e Hex CENTROTEC magnetic bit holder 60mm\u003c\/p\u003e\u003cp\u003e1 x 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e Hex CENTROTEC magnetic bit holder 120mm\u003c\/p\u003e\u003cp\u003e1 x 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e hex CENTROTEC 5mm TCT drill with depth stop\u003c\/p\u003e\u003cp\u003e1 x 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e hex CENTROTEC 3.5mm HSS drill with depth stop\u003c\/p\u003e\u003cp\u003e1 x 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e hex CENTROTEC 5mm hinge centring bit\u003c\/p\u003e\u003cp\u003e1 x 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e hex CENTROTEC hook driver\u003c\/p\u003e\u003cp\u003e1 x bit box (twinBOX BB-MIX)\u003c\/p\u003e\u003cp\u003e1 x drill bit case (BKS D3-8 CE\/W-K)\u003c\/p\u003e\u003cp\u003e1 x 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e CENTROTEC quick change bit holder (BHS 60 CE)\u003c\/p\u003e\u003cp\u003e1 x CENTROTEC fast change tool chuck with fast fix interface (WH-CE)\u003c\/p\u003e\u003cp\u003e1 x 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e hex CENTROTEC screwdriver handle (SD-CE-DRIVE-UNI)\u003c\/p\u003e\u003cp\u003e1 x Systainer SYS3 ORG M 89\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118440665435,"sku":"107949","price":499.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/107949_xl.jpg?v=1789780155","url":"https:\/\/www.axminstertools.com\/products\/festool-104-piece-centrotec-assembly-kit-in-t-loc-case","provider":"Axminster Tools","version":"1.0","type":"link"}
