260mm saw blades for the Festool KS 120 and KS 88 compound sliding mitre saws. Various options available; 80 teeth crosscut tooth saw blade for clean and splinter-free cross cuts in solid wood as well as for coated or veneered panels. 60T Blade for general purpose use, wood and soft plastics.
Festool
Festool 260mm TCT Saw Blades
| Blade Diameter | 260 mm |
| Maximum RPM | 5,800 rpm |
| Manufacturer Part Number | 494605 |
| Kerf | 2.5 mm |
| Teeth | 80 |
| Tooth Format | ATB |
| Plate Thickness | 1.8 mm |
| Hook Angle | 5 Negative Rake |
| Bore Size | 30 mm |
| Web Attribute Set | Circular Saw Blades - Power Tool |
| EAN Barcode | 4014549085462 |
