Festool
Festool 260mm TCT Saw Blades
SKU: 702263
£109.98
£91.65 Excl. VAT
  • Festool 260mm saw blades, 30mm bore
  • 80T blade for clean and splinter-free cross cuts in solid wood
  • 60T blade for general purpose use, wood and soft plastics
260mm saw blades for the Festool KS 120 and KS 88 compound sliding mitre saws. Various options available; 80 teeth crosscut tooth saw blade for clean and splinter-free cross cuts in solid wood as well as for coated or veneered panels. 60T Blade for general purpose use, wood and soft plastics.
Blade Diameter 260 mm
Maximum RPM 5,800 rpm
Manufacturer Part Number 494605
Kerf 2.5 mm
Teeth 60
Tooth Format ATB
Plate Thickness 1.8 mm
Hook Angle 5 Negative Rake
Bore Size 30 mm
Web Attribute Set Circular Saw Blades - Power Tool
EAN Barcode 4014549085479
