Festool GRANAT PROfile 150 mm abrasive discs are soft, foam‑backed abrasives developed for precise machine sanding on profiles, curves and contoured surfaces. The 13 mm polyurethane foam core adapts to uneven shapes, distributing pressure evenly to reduce the risk of breakthrough sanding and surface grooves.
Designed for controlled finishing, they deliver smooth, consistent results on wood, painted surfaces, fillers and modern coatings, including VOC‑compliant paints. Perfectly matched to Festool sanding machines, supporting efficient dust extraction and clean sanding within the Festool system.
Available in Medium, Fine, Super Fine and Mixed packs to suit every stage of surface preparation.
Compatible with Festool 150 mm random orbital sanders and also suitable for use with other 150 mm random orbital sanders.
