Festool GRANAT PROfile 80 × 133 mm abrasives provide controlled, machine‑guided sanding on profiles, recesses and complex shapes. The soft polyurethane foam core adapts to the workpiece, ensuring even pressure across mouldings and edges while minimising the risk of surface damage. Ideal for preparatory and finishing work, they deliver smooth results on wood, painted surfaces and filler compounds.
Available in a mixed pack containing 3 x Medium, 3 x Fine and 4 x Super Fine abrasives to support every sanding stage.
Compatible with Festool sanders using 80 x 133 mm sanding pads.
Abrasive Sheet Size 80 mm x 133 mm
Abrasive Material Granat
Manufacturer Part Number 578806
Abrasive Grit Mixed
Web Attribute Set Sanding Pads & Sponges
EAN Barcode 4014549465516
