Festool GRANAT PROfile Delta abrasives provide controlled, machine‑guided sanding on profiles, recesses and complex shapes. The soft polyurethane foam core adapts to the workpiece, ensuring even pressure across mouldings and edges while minimising the risk of surface damage. Ideal for preparatory and finishing work, they deliver smooth results on wood, painted surfaces and filler compounds.
Available in packs of 10; Medium P120-180, Fine P240-320 and Super Fine P500-600  to support every sanding stage.
Compatible with Festool sanders DTS400, DTSC400 and DS400 using Delta pad sanding pad 100 x 150mm.
Web Attribute Set Sanding Pads & Sponges
EAN Barcode 4014549465523
