These foam hand pads have two sides coated with silicon carbide abrasive. Hard wearing and long lasting they are available in a variety of grits. The pads are 120 x 98 x 13mm thick. They are useful for sanding off filler or repair compound on flat or gently curved surfaces. The tough silicon carbide abrasive is effective on paint, varnish, lacquer etc. Use these to gently soften edges on unfinished timber.
Abrasive Material Silicon Carbide
Abrasive Backing Foam
Manufacturer Part Number 201112
Abrasive Grit 60
Web Attribute Set Sanding Pads & Sponges
EAN Barcode 4014549254035
