{"product_id":"festool-abrasive-systainer-with-delta-granat-abrasive","title":"Festool Abrasive Systainer with Delta Granat Abrasive","description":"\u003cp\u003eThe ultimate solution for your delta sander – the abrasives Systainer. This convenient set is designed to keep your abrasives neatly arranged and easily accessible, making it the perfect addition to your sander. With a wide selection of grit sizes, it offers an excellent introduction to the world of GRANAT abrasives. GRANAT with its tough aluminium oxide and hard ceramic grit is long lasting and can be used on many different materials.\u003c\/p\u003e\u003cp\u003eThe abrasives Systainer includes 100x GRANAT sanding discs in grit sizes ranging from P60 to P220, ensuring you always have the right grit size at hand. It is the perfect addition to your sander as the Systainer holds 20x GRANAT sanding discs each in grit sizes P60, P80, P120, P180 and P220. Each compartment is organised by grit size, allowing you to find the required disc in seconds. The easy filling system ensures you always have an ample supply of the necessary grit size.\u003c\/p\u003e\u003cp\u003eThe GRANAT sanding discs are specially suited for VOC varnishes and hard substrates. Thanks to their special coating, clogging is avoided, ensuring a long service life. Additionally, other substrates can be processed with the GRANAT abrasive without any issues. The discs are also FSC™-certified, making them an environmentally friendly choice.\u003c\/p\u003e\u003cp\u003eSupplied in a SYS3 M112 Systainer with 100 x Delta Abrasives in total, 20 each; P60, P80, P120, P180, and P220.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118536806747,"sku":"112140","price":65.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/112140_xl.jpg?v=1789784742","url":"https:\/\/www.axminstertools.com\/products\/festool-abrasive-systainer-with-delta-granat-abrasive","provider":"Axminster Tools","version":"1.0","type":"link"}
