The Festool AN-XS FastFix Angle Attachment is a compact right-angle drilling and driving accessory designed to extend the versatility of compatible Festool cordless drills and screwdrivers. Allowing work in confined and difficult-to-reach areas, it is an ideal solution for installation, assembly and woodworking applications. Use the integrated 1/4 hex drive or add a Centrotec chuck or Festool 10mm chuck for maximum flexibility.
Featuring Festool's FastFix interface, the angle attachment can be fitted quickly and easily without tools, enabling rapid transitions between different drilling and driving tasks. The compact head design provides excellent access to corners, cabinet interiors and other restricted spaces where standard drill configurations may be impractical.
Engineered for smooth power transmission and reliable performance, the attachment maintains precise control while allowing users to work efficiently in awkward positions. Its durable construction ensures dependable operation in both workshop and site environments.
Ideal for cabinet makers, joiners, installers, kitchen fitters and maintenance professionals, the AN-XS FastFix Angle Attachment is well suited to furniture assembly and confined-space fastening applications.
Supplied ready to use on the following Festool drills with a FastFix interface; CXS12 and TXS 12 or CXS18 and TXS 18. Not suitable for CXS/TXS older models.
Manufacturer Part Number 205710
Web Attribute Set Festool Centrotec
EAN Barcode 4014549381687
