Suitable for Festool extractors with Autoclean, the 36mm hose improves extraction when the machine is producing a high volume of dust. This hose's robust and smooth outer casing makes all the difference to the service life and improves handling for the user. The hose glides smoothly over the surface without the suction hose becoming caught, meaning work is uninterrupted, convenient and safe.
The hose itself is antistatic, elastic and with reduced friction for increased suction power, you can achieve ideal results more quickly. 3.5m in length with a connecting sleeve diameter from 36mm to 32mm for better extraction. Featuring an RFID chip, the hose has automatic suction hose detection. It communicates the hose diameter on connection to a compatible Autoclean extractor, in order to ensure correct suction adjustments. The conical geometry of the suction hose reduces friction in the hose, meaning the airflow is increased and subsequently, the suction power.
This bayonet connection to your Festool power tool is quick and secure and it can be detached equally quickly. The bayonet connection features an infinitely adjustable bypass, which allows you to set the airflow rate to suit the power tool in use or particular task.
This feature enables you to work efficiently with different tools, cleanly and systematically. Its compact design won’t interfere with the handling of the power tool and the rotating adapter prevents the hose from twisting.
The bayonet connection conveniently fits into the opposite end for storage and transport, keeping any remaining dust in the hose. This feature also allows you to join two or more hoses for extended reach.
Suitable for Festool extractor with Autoclean.
