These HSS spiral drills have a CENTROTEC bit holder which is suitable for use in all CENTROTEC quick change chucks or a standard drill chuck. The high-speed steel drill bit is suitable for drilling wood, plastic and non-ferrous metals. Supplied with CENTROTEC holder and 2 drill bits which are easy to interchange with a hex key. Available in 4 sizes; 3mm, 3.5mm, 4mm or 5mm.
Manufacturer Part Number 493421
Drill Bit Diameter 3.0 mm
Web Attribute Set Festool Centrotec
EAN Barcode 4014549050132
