{"product_id":"festool-circular-saw-blade-set-3-wood-plastics-260mm","title":"Festool Circular Saw Blade Set 3, Wood \u0026 Plastics  260mm","description":"\u003cp\u003eThe Festool Circular Saw Blade (Set of 3) is an essential set for your most frequent sawing applications. This value pack is ideal for stocking or equipping multiple saws, comprising the most frequently used circular saw blades for wood, aluminium, and plastic. The high-quality and robust carbide teeth ensure a long service life with consistent cutting quality, and they can be resharpened easily. Festool's colour-coding allows for quick access to the right blade, making sawing even more enjoyable.\u003c\/p\u003e\u003cp\u003eThis pack contains 3 blades; 260mm diameter and 30mm bore for mitre saws.\u003c\/p\u003e\u003cp\u003eFine cutting wood blade with 80 tooth for cross and angle cuts, 2.5mm kerf.\u003c\/p\u003e\u003cp\u003eUniversal wood and soft plastic cutting blade, 60 tooth for precise cross cuts, 2.5mm kerf.\u003c\/p\u003e\u003cp\u003eAluminium and Plastics TF blade with 68 tooth for trimming aluminium profiles and all types of hard and fibre reinforced plastics specially adapted to the application. 2.4mm kerf.\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118642942299,"sku":"113045","price":295.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113045_xl.jpg?v=1789789281","url":"https:\/\/www.axminstertools.com\/products\/festool-circular-saw-blade-set-3-wood-plastics-260mm","provider":"Axminster Tools","version":"1.0","type":"link"}
