Festool
Festool CTL SYS CLEANTEC Dust Extractor
SKU: 104549
£382.58
£318.82 Excl. VAT
  • 3m smooth extraction hose improves extraction efficiency
  • Smooth outer skin means an end to snagging on edges
  • CLEANTEC bayonet fitting ensures a secure connection
  • T-LOC coupling for easily transportable modular setup
  • Highly mobile, shoulder strap leaves hands free
  • Automatic activation when power tool switched-on
  • Manual mode for cleaning work
  • Meets dust class "L" standard, suitable for dry extraction only
Perfectly integrated in a Systainer case, the Festool CLEANTEC CTL SYS offers you maximum mobility and flexibility. It is ideally suited for maintenance and installation work. Compatible with the Festool Systainer T-LOC system, it couples with Systainers and Sortainers forming an easily transportable modular setup. Using the shoulder strap to carry the unit leaves your hands free.
The L class filters up to 99% of hazardous dust with limit values greater than 1 mg/m³ creating a healthier and cleaner working environment.
The smooth extraction hose greatly improves efficiency. Reduced internal friction increases the airflow rate and therefore the suction power. The smooth outer skin means you no longer need worry about ribbed hose snagging on edges or inadvertently damaging a workpiece. The CLEANTEC bayonet fitting ensures a secure connection to your power tool and a quick disconnection.
The upholstery and crevice nozzles sit neatly underneath the lid of the dust extractor. The dust box is easily removable at the touch of a button for emptying or changing the filter. A socket with an automatic switch activates the CTL SYS as soon as you switch on a connected power tool. There is a manual mode for cleaning work.
The CLEANTEC CTL SYS is a certified dust extractor that meets dust class L standard. Supplied with fitted filter bag, 3m smooth suction hose, hose holder, Sys-Dock with T-LOC function, upholstery nozzle, crevice nozzle and carrying strap.
All Festool dust extractors offer dust-free working conditions in combination with both electrical and pneumatic machines.
Please ensure that any dust extractor is suitable for the type of dust produced before ordering. The L class is for general work. If you are routing or sanding MDF, man-made boards or all solid woods (oak, beech etc.), you should use an M class extractor.
Overall L x W x H 396 mm x 296 mm x 270 mm
Rating Trade/Professional
Additional Accessories Yes
Corded or Cordless Corded
Cable Length 5 m
Max Capacity Dry 4.5 litre
Airflow Volume 3,000 litre/min
Sound Pressure Level LpA [Uncertainty K] 67 dB(A) [3.0 dB]
Motor Power 1,000 W
Plug Fitted UK 3 pin plug
Manufacturer Part Number 575284
Web Attribute Set Power Tool Extractors
EAN Barcode 4014549298312
