The Festool CTM 26 EI AC CLEANTEC Dust Extractor 230V is a high-performance dust extraction system designed to meet the needs of professional woodworkers. The M class CTM 26L filters 99.9% of hazardous dust with limit values greater than 0.1 mg/m³ for a safer, healthy and clean working environment. M class dust extractors are suitable for vacuuming/extracting dry, non-combustible dusts, non-combustible liquids, wood dusts and hazardous dusts with STELs >0.1mg/m³. The extractor features an automatic main filter cleaning system (AUTOCLEAN) that ensures continuous high suction power by preventing filter clogging.
With a 26-litre container capacity, it provides ample space for dust collection, making it suitable for both small and large woodworking projects. The compact design, combined with swivelling castor wheels and rear wheels, ensures optimum mobility and stability, whether used in the workshop or on a construction site.
The Power Take Off (PTO) feature is a plug socket, found on the wet and dry vacuum cleaner, that synchronises the operation of the vacuum cleaner with your power tool. So, when you switch on the power tool you are using, the vacuum will automatically switch on too.
Customers will appreciate the Festool CTM 26 EI AC CLEANTEC Dust Extractor for its robust construction and practical features. The smooth, anti-static suction hose reduces internal friction, increasing airflow rate and suction power. The extractor is equipped with a locking brake for stability during transport and use. Additionally, the flat filter integrated into the suction head maximises container volume utilisation, ensuring efficient dust collection.
Supplied with disposal bag, end cap for intake adapter, high performance main filter, SELFCLEAN filter bag, and smooth suction hose diameter 27/32 x 3.5 m AS/CTR.
Overall L x W x H 630 x 365 x 540 mm
Rating Trade/Professional
Corded or Cordless Corded
Cable Length 7.5 m
Airflow Volume 3,900 litre/min
Sound Pressure Level LpA [Uncertainty K] 71 dB(A) [3.0 dB]
Manufacturer Part Number 577854
Web Attribute Set Power Tool Extractors
EAN Barcode 4014549430675
