Introducing the Festool Mobile Dust Extractor CLEANTEC CTM 26 EI 230V – the ultimate all-rounder for workshops and construction sites. The M class CLEANTEC CTM 26 EI 230V filters 99.9% of hazardous dust with limit values greater than 0.1 mg/m³ for a safer, healthy and clean working environment. M class dust extractors are suitable for vacuuming/extracting dry, non-combustible dusts, non-combustible liquids, wood dusts and hazardous dusts with STELs >0.1mg/m³. Suitable for wet or dry extraction (wet requires accessory filter).
This powerful extractor boasts a generous 26-litre container volume while maintaining a compact design, making it perfect for any workspace. With its intuitive touch operation, you can easily control the extractor, even when wearing gloves or working in a dirty environment.
The CLEANTEC CTM 26 EI is equipped with a permanently installed Bluetooth® interface, allowing you to start the extractor using a Festool cordless tool or optional remote control. You can also connect it to the Festool app for seamless integration and support. The smooth, anti-static suction hose can be conveniently stowed away in the integrated hose holder, ensuring a tidy workspace.
The Power Take Off (PTO) feature is a plug socket, found on the wet and dry vacuum cleaner, that synchronises the operation of the vacuum cleaner with your power tool. So, when you switch on the power tool you are using, the vacuum will automatically switch on too.
Thanks to the T-LOC system, you can quickly connect Systainers, pre-separators, or Workcenters, making the extractor the central point of your system. The high-performance turbine ensures constantly high suction power, while the large pivoting rollers and integrated brake provide optimal mobility and stability.
Whether you're dealing with hazardous wood dust or mineral dust, the CLEANTEC CTM 26 EI is approved for dust class M, ensuring a safe and clean working environment. Its robust design and flexible features make it a reliable companion for years to come. Experience the convenience and efficiency of the Festool Mobile Dust Extractor CLEANTEC CTM 26 EI 230V – your go-to solution for clean and efficient work.
Comes with main filter, SELFCLEAN filter bag, and smooth suction hose diameter 27/32 x 3.5 m AS/CTR.
Overall L x W x H 630 x 365 x 540 mm
Rating Trade/Professional
Corded or Cordless Corded
Cable Length 7.5 m
Airflow Volume 3,900 litre/min
Sound Pressure Level LpA [Uncertainty K] 71 dB(A)
Manufacturer Part Number 577920
Web Attribute Set Power Tool Extractors
EAN Barcode 4014549431498
