The Festool CXS 18 is a compact and powerful cordless tool for drilling and screwdriving, featuring the high build quality and long service life that Festool is known for. The CXS 18 Basic Cordless Drill is ideal for everyday use and is designed for light to medium applications. Its power, low weight and impressive ergonomics ensure you have full control and make drilling and fastening an effortless task.
This cordless drill features a maintenance free brushless E-Tec motor for unrivalled performance. When powered by a Festool 18V battery (not included), it can bore a 35mm hole with a Forstner bit or drive a 6 x 240mm screw into softwood. A compact tool with a short length of only 156mm, 1/4 hex bits can be inserted directly into the FastFix spindle for screwdriving or drilling in cramped spaces. The 10mm keyless chuck fits directly onto the FastFix interface and an integrated LED light illuminates the working area – adjustable in the Festool App.
The FastFix interface makes the CXS 18 fully compatible with the full range of Festool FastFix attachments. It can also accept a Festool CENTROTEC tool chuck, offering almost instant changing between drilling, countersinking and screwdriving bits.
Supplied with: FastFix BF-FX 10mm keyless chuck, belt clip and a Systainer SYS3 DF M 187 carry case with lid compartment
Note: this is a body only tool supplied without batteries or charger. Part of the Festool 18V family of batteries and chargers.
Battery Voltage 18 V
Sound Power Level LwA [Uncertainty K] 82 dB(A) [1.5 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Chuck Capacity 1 mm to 10 mm
Chuck Type keyless
Sound Pressure Level LpA [Uncertainty K] 74 dB(A) [1.5 dB]
Manufacturer Part Number 577286
EAN Barcode 4014549404706
