Festool
Festool CXS12 2.5 Set Cordless Drill Driver 12V (2 x 2.5Ah)
SKU: 109891
£329.98
£274.98 Excl. VAT
  • Compact and light-weight design
  • Powerful cordless drill driver set for effortless working
  • FastFix spindle takes full range of 18V accessories
  • 2 x 12V 2.5Ah battery included plus charger
  • LED light for work in poorly lit areas
  • CENTROTEC system for quick accessory change
  • FastFix elbow adaptor gets into very tight areas
  • 2 chucks - 10mm FastFix chuck and CENTROTEC tool chuck
  • Supplied in Systainer SYS3 DF M187 case with lid compartment
The smallest product in the Festool 12V range but it packs a strong, cordless punch, and a welcome companion to the Festool 18V family.
Built to the highest quality with a long service life that Festool pride's themselves on, the CXS 12 is no exception, its compact, cordless, strong and precise, your perfect go to tool when you need to get into tight spaces or narrow corners. The CXS has a 'C' shape handle and is very comfortable to use.
Powered by a 12V Li-ion battery (included) combined with the maintenance free brushless E-Tec motor for unrivaled performance, along with electronic variable speed control with torque shut off to give the right screwdriving force in any material.
The FastFix interface makes the CXS 12 fully compatible with the full range of Festool FastFix attachments. The interface also allows 1/4 shank bits to be inserted directly lessening the drill length even further for tight areas. The 3 chucks supplied are CENTROTEC, 10mm keyless chuck and FastFix Angle attachment.
The CENTROTEC tool chuck offers incredibly quick changing between drilling, countersinking and screwdriving bits. The 10mm keyless chuck can take standard 1/4 hex fitting bits and round shank accessories up to 10mm shank and the FastFix Angle Attachment is perfect for tight spaces and has a 1/4 direct bit holder or you can add either CENTROTEC or 10mm Chuck.
The CXS 12 comes fitted with an LED light for working in dark, cramped corners and, 1/4 hex bits can be inserted directly into the FastFix spindle for screwdriving or drilling in tight spaces. The practical magnetic bit holder on the drill provides handy storage.
Supplied with: FastFix BF-FX 10mm keyless chuck, CENTROTEC WH-CE chuck, AN-XS Angle attachment. 2 x 12V 2.5Ah Li-on batteries, rapid charger TCL 6, belt clip, PZ2 bit, CENTROTEC BH 60CE Imp Magnetic bit holder in a SYS3 DF M187 Systainer case with lid cassette.
Battery Capacity 2.5 Ah
Battery Voltage 12 V
Rating Trade/Professional
Reverse No
Sound Power Level LwA [Uncertainty K] 86 dB(A)
Batteries Included 2
Battery Type Li-ion
Corded or Cordless Cordless
Chuck Capacity 1 mm to 10 mm
Chuck Type keyless
Sound Pressure Level LpA [Uncertainty K] 75 dB(A)
Manufacturer Part Number 576867
Web Attribute Set Cordless Drill Drivers
EAN Barcode 4014549383483
