This Festool Polycrystalline diamond (PCD) tipped saw blade, when fitted to the TS 55R or TSC 55 and used in combination with a guide rail, is the ultimate problem solver for cutting all chipboards and fibreboards bound with cement or gypsum. The Festool blade offers rapid progress, high performance, low wear and results in greater working efficiency, as with all things Festool.
Dimensions: diamond saw blade 160mm (diameter) x 2.2mm (kerf) x 20mm (bore size).
The cutting depth can be adjusted accurately to 1/10mm. (Reference: 160x2, 2x20 DIA4).
This Festool diamond saw blade will not fit older pre-2012 TS55 models.
Blade Diameter 160 mm
Maximum RPM 11,000 rpm
Manufacturer Part Number 201910
Kerf 2.2 mm
Teeth 4
Tooth Format F
Plate Thickness 1.6 mm
Hook Angle 10
Bore Size 20 mm
Web Attribute Set Circular Saw Blades - Power Tool
EAN Barcode 4014549274439
