{"product_id":"festool-domino-df-500-connector-set-kv-sys-d8","title":"Festool DOMINO DF 500 Connector Set KV-SYS D8","description":"\u003cp\u003eThis DOMINO KV-SYS-D8 connector system allows you to produce highly accurate and strong knockdown joinery simply and quickly.\u003c\/p\u003e\u003cp\u003eThe joints are easy to assemble, disassemble and reassemble. All joints are simple and quick to machine using the DOMINO DF 500 jointer; the only additional tool needed is a drill with which to bore a single hole for the tightening the connector. The joints are strong, tight and unobtrusive with a neat cover cap the only clue to its existence.\u003c\/p\u003e\u003cp\u003eThe system offers increased flexibility for a wide range of applications. It will produce panels with corner ‘L’ joints, centre ‘T’ joints or centre panel joints through a panel and joints between a series of holes. The system makes it significantly easier to assemble a piece of furniture, even working alone. The DOMINO KV-SYS-D8 is suitable for materials with a thickness between 18mm and 28mm.\u003c\/p\u003e\u003cp\u003eThe DOMINO DF 500 Connector Assortment Systainer offers the best value to get you started with the system.\u003c\/p\u003e\u003cp\u003eSupplied in a SYS 1 T-LOC Systainer containing:\u003c\/p\u003e\u003cp\u003e70 x DOMINO\/DOMINO KV D8 basic structure connector\u003c\/p\u003e\u003cp\u003e20 x DOMINO\/LR32 KV-LR32 D8 basic structure connector\u003c\/p\u003e\u003cp\u003e10 x DOMINO\/DOMINO MSV D8 centre panel connector\u003c\/p\u003e\u003cp\u003e10 x DOMINO\/LR32 MSV-LR32 D8 centre panel connector\u003c\/p\u003e\u003cp\u003e50 x Dark brown cover caps\u003c\/p\u003e\u003cp\u003e50 x Silver cover caps\u003c\/p\u003e\u003cp\u003e50 x White cover caps\u003c\/p\u003e\u003cp\u003e50 x Grey cover caps\u003c\/p\u003e\u003cp\u003e20 x DOMINO D 8 x 36 mm\u003c\/p\u003e\u003cp\u003e1 x BS-KV D15 drill template, 203164\u003c\/p\u003e\u003cp\u003e1 x KVB-HW D15 CE hinge location cutter, 203165\u003c\/p\u003e\u003cp\u003e1 x Screwdriver\u003c\/p\u003e\u003cp\u003eThe Festool wooden dowels included are certified by the Pan European Forest Council (PEFC)\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118304383323,"sku":"104725","price":429.88,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104725_xl.jpg?v=1789774607","url":"https:\/\/www.axminstertools.com\/products\/festool-domino-df-500-connector-set-kv-sys-d8","provider":"Axminster Tools","version":"1.0","type":"link"}
