The SV-AB D14 anchor bolt is the central element of a corner of frame connection. It requires the SV-SA D14 split anchor and the SV-QA D14 cross anchor to form the complete joint. Other parts can be purchased separately.
The DOMINO connector revolution makes fast, accurate and powerful connections with the option of quick and easy disassembly and reassembly. The corner and flat connector system for the DOMINO XL DF 700 joining machine is suitable for material thicknesses of 30mm or more.
Using the DOMINO XL DF 700 to produce the joint is an extremely quick process using only the machine’s stops or simple pencil markings. It requires no other accessories or templates. The finished joint is extremely stable. Cover caps are available in three colours for a high-quality corner connection appearance. Supplied in boxes of 32.
Manufacturer Part Number 201350
Web Attribute Set Dowelling Jointers Accessories
EAN Barcode 4014549259672
