{"product_id":"festool-domino-df-700-connector-range-sv-sys-d14","title":"Festool DOMINO DF 700 Connector Range SV-SYS D14","description":"\u003cp\u003eThe DOMINO connector revolution makes fast, accurate and powerful connections with the option of quick and easy disassembly and reassembly. The connector system for the DOMINO XL DF 700 joining machine is suitable for material thicknesses of 30mm or more.\u003c\/p\u003e\u003cp\u003eContained within a Festool Systainer SYS-2 are all the elements in the connector system. There are sufficient to make several corner, frame or butt joints. The Systainer allows you see at a glance when certain elements require topping up. Comprises 32 of each: SV-AB D14 anchor bolts; SV-SA D14 split anchors, SV-V D14 widener for cross anchors and DOMINO D 14 x 75mm birch dowels. Plus 96 cover caps (32 of each colour), 16 SV-DB D14 double-headed bolts and 64 SV-QA D14 cross anchors. Lastly, the kit includes a wrench for tightening the cross anchor set screws.\u003c\/p\u003e\u003cp\u003eUsing the DOMINO XL DF 700 to produce the joint is an extremely quick process using only the machines' stops or simple pencil markings. It requires no other accessories or templates. The finished joint is extremely stable.\u003c\/p\u003e\u003cp\u003eSupplied in a SYS3 M 137 systainer case\u003c\/p\u003e\u003cp\u003eN.B. The kit does not include the D14 cutter, this will need to be purchased separately (part no. 501639)\u003c\/p\u003e\u003cp\u003eThe Festool wooden dowels included are certified by the Pan European Forest Council (PEFC)\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54118187762011,"sku":"102316","price":275.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/102316_xl.jpg?v=1789771829","url":"https:\/\/www.axminstertools.com\/products\/festool-domino-df-700-connector-range-sv-sys-d14","provider":"Axminster Tools","version":"1.0","type":"link"}
