The DOMINO EV/32 connector set contains a sufficient quantity of the three elements you need to make several corner or frame joints. It comprises 32 of each: SV-AB D14 anchor bolts; SV-SA D14 split anchors and SV-QA D14 cross anchors.
The DOMINO connector revolution makes fast, accurate and powerful connections with the option of quick and easy disassembly and reassembly. The connector system for the DOMINO XL DF 700 joining machine is suitable for material thicknesses of 30mm or more.
Using the DOMINO XL DF 700 to produce the joint is an extremely quick process using only the machine’s stops or simple pencil markings. It requires no other accessories or templates. The finished joint is extremely stable.
