Upgraded version of the EHL 65 Festool Planer with a more compact design and other small improvements to make the machine more refined. The cutting block is fitted with a ground solid carbide blade that gives a shear cutting action across the width of the planer block resulting in a very fine finish. Maximum cutting depth of 4mm (accurately controlled in 0.1mm steps), this machine offers fast waste removal with easily handling. Although using only a single blade, the balance of the cutter block is very fine reducing vibration to a minimum. Changing the blade is simple and no further settings are required. The overall size and layout of the planer make it very easy to use single-handed.
Festool
Festool EHL 65 EQ Planer
| Dust Extraction | 27 mm Outlet |
| Sound Power Level LwA [Uncertainty K] | 88 dB(A) [3.0 dB] |
| Corded or Cordless | Corded |
| Sound Pressure Level LpA [Uncertainty K] | 77 dB(A) [3.0 dB] |
| Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
| Motor Power | 720 W |
| Manufacturer Part Number | 574560 |
| Voltage | 230 V |
| Web Attribute Set | Power Planers |
| EAN Barcode | 4014549193730 |
