{"product_id":"festool-ehl-65-eq-planer","title":"Festool EHL 65 EQ Planer","description":"\u003cp\u003eUpgraded version of the EHL 65 Festool Planer with a more compact design and other small improvements to make the machine more refined. The cutting block is fitted with a ground solid carbide blade that gives a shear cutting action across the width of the planer block resulting in a very fine finish. Maximum cutting depth of 4mm (accurately controlled in 0.1mm steps), this machine offers fast waste removal with easily handling. Although using only a single blade, the balance of the cutter block is very fine reducing vibration to a minimum. Changing the blade is simple and no further settings are required. The overall size and layout of the planer make it very easy to use single-handed. \u003cspecial id=\"22\"\u003e\u003c\/special\u003eSupplied complete with parallel side fence, plug-it cable and Supplied in Systainer SYS3 M 187 case.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54117792579931,"sku":"503830","price":359.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/503830_xl.jpg?v=1790104367","url":"https:\/\/www.axminstertools.com\/products\/festool-ehl-65-eq-planer","provider":"Axminster Tools","version":"1.0","type":"link"}
