Festool
Festool ERSC 18 EB-BASIC Reciprocating Saw 18V (Body Only)
SKU: 114800
£282.98
£235.82 Excl. VAT
  • Powerful 18V cordless reciprocating saw for professional cutting applications
  • High-performance brushless EC-TEC motor for long service life
  • Suitable for cutting wood, metal, plastics and composite materials
  • Variable speed control for greater cutting precision and material control
  • Adjustable pendulum action for faster cuts and improved blade performance
  • Tool-free blade changes for quick and easy accessory replacement
  • Compact and ergonomic design for improved handling
  • Low-vibration operation enhances user comfort during extended use
  • Ideal for demolition, renovation and installation work
  • Cordless design provides maximum freedom of movement on site
  • Compatible with Festool 18V batteries and chargers
The Festool ERSC 18 EB-Basic Cordless Reciprocating Saw is a powerful and versatile 18V cutting tool designed for fast, efficient demolition, renovation and construction work. Combining high cutting performance with a compact, ergonomic design, it is equally suited to cutting wood, metal, plastics and composite materials, making it an ideal choice for professional tradespeople working on site.
Engineered for demanding applications, the ERSC 18 Reciprocating Saw features a high-performance brushless EC-TEC motor and variable speed control, delivering fast cutting progress while maintaining excellent control across a wide range of materials. The tool-free saw blade change system enables quick blade swaps, while the pendulum action can be adjusted to optimise cutting speed and blade life for different tasks.
With its compact design and balanced handling, this saw is well suited to overhead work, confined spaces and extended periods of use. Integrated vibration damping helps improve user comfort, while the rubberised grip provides secure handling in challenging working conditions. The cordless design offers maximum mobility around site without the restrictions of power leads.
Ideal for builders, renovators, electricians, plumbers, installers and maintenance professionals, the ERSC 18 is well suited to demolition work, pruning, pipe cutting, timber cutting and general site applications.
The Festool ERSC 18 EB-Basic Cordless Reciprocating Saw is compatible with Festool 18V batteries and chargers and fully integrated into the Festool cordless system, allowing users to share batteries across a wide range of professional cordless tools for greater flexibility and efficiency.
Supplied as a body only machine. Batteries and charger available separately. Supplied with; Universal wood blade, extraction connector and Syatainer SYS3 M 187.
Battery Voltage 18 V
Rating Trade/Professional
Stroke Length 25.4 mm
Sound Power Level LwA [Uncertainty K] 98 dB(A)
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 90 dB(A)
Vibration Cutting Wood [Uncertainty K] 5.0 m/s²
Manufacturer Part Number 578691
Web Attribute Set Cordless Sabre Saws
EAN Barcode 4014549458938
