The Festool ETS 125 REQ 125mm compact eccentric sander is well balanced and easily manoeuvrable. At 1.2kg, it is light in weight and comfortable when used for sanding vertical or overhead surfaces with a single handed grip. The ETS 125 REQ features Festool’s MMC control electronics. The sander has a variable speed selector; the MMC control maintains the chosen speed under load. With all 250W of power in use, work proceeds at a rapid rate. The 2mm orbit and eccentric action leave an excellent surface finish in a short space of time. The clip-on light module illuminates your sanding area and makes it easier to recognise unevenness. Thanks to vibration detection, the light module switches on and off automatically, and can be set to full or dimmed light. The ETS 125 REQ-PLUS includes a Longlife dust bag made from a durable polyester fleece. It is highly effective and easy to empty. Alternatively, you can connect to an extractor; the dust outlet is compatible with Festool’s Cleantec connection system. The PROTECTOR is an effective clip-on skirt around the sanding pad that eliminates the risk of damage when working against an adjacent vertical surface for example. Supplied with 125mm diameter StickFix sanding pad (soft-HT), edge PROTECTOR, light module, Longlife chip collection bag and Systainer SYS 2 T-LOC case.
Dust Collection Dust Bag Supplied
Dust Extraction 27 mm Outlet
No Load Speed 6,000 - 12,000 rpm
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 84 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 73 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 3.5 m/s² [1.5 m/s²]
Motor Power 250 W
Plug Fitted UK 3 pin plug
Manufacturer Part Number 201233
Web Attribute Set Random Orbit Sanders
EAN Barcode 4014549255360
