{"product_id":"festool-ets-150-3-eq-plus-sander","title":"Festool ETS 150\/3-EQ Plus Sander","description":"\u003cp\u003eThe ETS 150mm sander pad is eccentric in action with minimal vibration for excellent working results. With a 3mm orbit it is suitable for fine finishing, sanding wood, varnish, paint, fillers and plastic.\u003c\/p\u003e\u003cp\u003eYou can be assured of a faultless finish with step less speed preselection so you can choose the correct speed to suit the work, constant electronics for consistent speed under load and a sanding pad brake. Fitted with dual bearings that make them very durable and Plug it cable system.\u003c\/p\u003e\u003cp\u003eFitted with a MULTI-JETSTREAM 2 pad, this works using intake air and exhaust air to generate airflow transporting the sanding dust away from the pads surface so that the abrasive wears evenly without clogging as well as keeping the surface at a low temperature. The result  is almost 100% dust extraction for an improved rate of material removal, a better finish and a healthy working environment. Made from MPE high tear resistant material the pad is also very durable.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eSupplied with MULTI-JETSTREAM 2 sanding base (soft), disposable dust bag and stacking Systainer\u003cspecial id=\"9\"\u003e\u003c\/special\u003e T-LOC SYS3 storage case.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Festool","offers":[{"title":"Default Title","offer_id":54115806380379,"sku":"410327","price":449.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/410327_xl.jpg?v=1789756853","url":"https:\/\/www.axminstertools.com\/products\/festool-ets-150-3-eq-plus-sander","provider":"Axminster Tools","version":"1.0","type":"link"}
