{"product_id":"festool-ets-ec-eccentric-sander-150-3-150-5","title":"Festool ETS EC Eccentric Sander 150\/3 \u0026 150\/5","description":"\u003cp\u003eThese Festool sanders have been specifically designed with comfort as a primary consideration. They will considerably reduce fatigue when, for example, sanding overhead as thanks to the ergonomic design there are various ways of holding these tools, ensuring a comfortable grip at all times.\u003c\/p\u003e\u003cp\u003eThe ETS EC 150 has a number of important features, the first being working height of just 116mm, ensuring that access to limited work areas is unimpeded.  Secondly, there’s a powerful brushless EC-TEC motor, which is contained in a sophisticated housing with a balanced centre of gravity.  This makes the ETS EC 150 the ideal one-handed sander for achieving a blemish free and flawless surface.\u003c\/p\u003e\u003cp\u003eThe sander incorporates a new Vibration Control System, which actively regulates the speed of the motor if vibrations are too great.  This results in a quieter, smoother operation and a greatly improved feel with noticeably fewer vibrations.\u003c\/p\u003e\u003cp\u003eThe machine also has a unique suction detection system. When activated, it ensures that the sander will only start if a suction hose is connected. This function can be disabled if required and an audio beep lets you know what function it is in.\u003c\/p\u003e\u003cp\u003eThe carbide tipped, pad brake prevents the sanding pad from revolving too quickly when in a no-load state and it also allows the machine to be applied to a surface without producing grooves.\u003c\/p\u003e\u003cp\u003eAvailable as the ETS EC 150\/3 with a 3mm sanding orbit stroke for fine sanding and extra fine sanding or alternatively as the ETS 150\/5 with a 5mm sanding orbit stroke for light sanding and intermediate sanding on varnish or paint.\u003c\/p\u003e\u003cp\u003eFitted with a MULTI-JETSTREAM 2 pad, this works using intake air and exhaust air to generate airflow transporting the sanding dust away from the pads surface so that the abrasive wears evenly without clogging as well as keeping the surface at a low temperature. The result  is almost 100% dust extraction for an improved rate of material removal, a better finish and a healthy working environment.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eSupplied with a MULTI-JETSTREAM 2  sanding pad and plug-it cable in a SYSTAINER SYS 2T-LOC.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Festool","offers":[{"title":"3.0 mm","offer_id":54117950226779,"sku":"506716","price":619.98,"currency_code":"GBP","in_stock":true},{"title":"5.0 mm","offer_id":54117950259547,"sku":"506717","price":619.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/506716_xl.jpg?v=1789770276","url":"https:\/\/www.axminstertools.com\/products\/festool-ets-ec-eccentric-sander-150-3-150-5","provider":"Axminster Tools","version":"1.0","type":"link"}
