The Festool FS-WA-VL guide extension includes two connectors and an adjustable repeat stop. It is designed to attach to the FS-WA Angle Stop, forming a longer bearing face to register on the edge of your workpiece. The extension has a scale, using the adjustable stop allows cuts to be easily made to size with repeat accuracy. The adjustable repeat stop locks onto the extension for accurate repeat cuts from 447mm to 1,150mm wide.
Manufacturer Part Number 577041
EAN Barcode 4014549391747
