The FSV/2 connects two guide rails as if they were made from a single piece. They ensure precise cuts over the entire length of two or more connected guide rails. The two connecting pieces allow you to join two guide rails ensuring the result is straight, true and stable. The self-aligning function makes them quick and convenient to use. The connecting pieces are compatible with all Festool guide rails. The laser engraving ensures that the two connecting pieces are used in the correct order.
Manufacturer Part Number 577039
EAN Barcode 4014549391723
